21 years agonios2-terminal
Hello, I added a 8 bit pio (input only, no interrupt) to a standard feature 2c35. The compiling as successful. For testing I used the counter-example. The program is transfered, starts. But I...
21 years agoThat would be caused by the embedded side. Does your software send that character? (not sure what the value is so you'd have to look it up in an ASCII table). One of the software examples in the Nios II IDE uses this character to break the communication after the program finishes (closes the terminal connection in a clean way).
