20 years agonios2-terminal
As you can see in the follows pict, i would like to download the vmlinux in flash memory. But i've this error message when i want launch the command. I don't know why... http://forum.niosfor...
20 years agohi,
another tip : if u are using byteBlaster download cable u will have intermitant problem like "exiting due to I/O errors". but u can do the following : --> if your IP @ddress is still not configured so go to file system : /etc/rc and uncomment the line :# ifattch ... and configure the IP address --> after configuring the device u can access the uClinux by telenet instead of nios2terminal : it's more fast http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
