16 years ago
Nios2 SPI
I'm having some trouble reading from my IO expander with the SPI core from Altera :confused:
Can anybody provide me with an example on how to issue a correct read to the spi interface with the 'alt_avalon_spi_command' ??
-mitch
    I use something like that
     IOWR(SPI_CYCLONE3_BASE, ALTERA_AVALON_SPI_TXDATA_REG, tosend);
        while (!(IORD(SPI_CYCLONE3_BASE, ALTERA_AVALON_SPI_STATUS_REG) &  0x0020));
        return IORD(SPI_CYCLONE3_BASE, ALTERA_AVALON_SPI_RXDATA_REG);
    could you show me the your complete code for your spi interface?
    I send 16bits. 1 read/write bit, 7 address bits and 8 datas bits.
    void  WriteReg(alt_u8 adress, alt_u8 m_data)
        alt_u16 tosend;
        tosend = 0x8000 | ((adress << 8) & 0x7F00) | (m_data & 0x00FF);
    alt_u8  ReadReg(alt_u8 adress)
        alt_u16 tosend;
        tosend = (adress << 8) & 0x7F00;
    Hi
    I have the similar problem-i can write to the register, but when i try to read from register, i dont became anything, all signals-CS, CLK, MISO are 0...
    alt_spi_command run also, but only when i write to register...
    can anybody help me, any suggestion?
    I ended up using the standard NIOS spi command like this:
    Write :
    wdata = 0x40; // Write command of the chip
    wdata = 0x09; // register adr
    wdata = 0x2;  // value
    alt_avalon_spi_command(SPI0_BASE, 0,
    3,
    wdata,
    0,
    rdata,
    0);
    Read :
    wdata = 0x41; // read command
    wdata = 0x12; // register adr
    ID = 0;
    2,
    wdata,
    2, // reading 2 bytes
    rdata, // store bytes here
    0);
    Hope this helps :)
    and how would that work without the standard command?
    I'm an altera newbee and have the same problem.
    i need to send 7 bit reg-addr.+1bit r/w and 16 bit data
    I'm trying with
    #include
    <altera_avalon_spi_regs.h>
    #include <altera_avalon_spi.h>
    main{
    int test;
    while (!(IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE) & ALTERA_AVALON_SPI_STATUS_TRDY_MSK));
    IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE, 0xFFFF);
    test=IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE);
    but the thinks i write dont match with the read data... :(
    Any help?
