21 years agoNios2 SDRAM+LAN bus sharing
Hi all! I have been attempting to use the bus-sharing feature of the SDRAM controller, along with the LAN controller. The SDRAM seems to be working okay!, but so far no luck with the LAN cont...
21 years agoI agree with gmm... I would expect Quiartus to give a compilation error becaue of a mis-matched bus width; you are attempting to throw away 4 address lines but Quartus doesn't know that.
You should try this in case you're seeing such a compilation error:addr ( from SOPCB ) ---- name the bus "my_addr"----x the 'x' means that you don't connect the line to anything. then, to get to your pin, make a separate named bus wire like this: x----name this one "my_addr"--------<<--IO named "my_addr-->> Then quartus knows explicity that you want to connect 11..0 on your IO to 11..0 on the bus coming from the SOPCB module.
