21 years agoNios2 Performance
I just ran some benchmarks for an ARM922 and a NIOS2/f. Both were run with the same code and ran at 90MHz. I did benchmarks for interger multiply, integer divide, floating point multiply, and float...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- BTW, BadOmen to which amount of quoted cycles are you reffering[/b] --- Quote End --- ---> oops wrong post. Someone (maybe rppolicy, or maybe it was you) did some benchmarking on the software floating point times (I was thinking of that and forgot it wasn't in this post but somewhere else in the forum).
