21 years agoNios2 Performance
I just ran some benchmarks for an ARM922 and a NIOS2/f. Both were run with the same code and ran at 90MHz. I did benchmarks for interger multiply, integer divide, floating point multiply, and float...
21 years ago --- Quote Start --- originally posted by anagnost@Jan 20 2005, 05:44 PM jesse: i do not think that adding a hardware fp to nios ii and then comparing it with an arm using a software fp and a hardware barrel shifter (which by the way nios ii/f also has) would make things fair. i think that this is exactly what would make thinks unfair. i think it would be then like comparing apples to oranges to use badomen's expression. --- Quote End --- I am sorry if I was ambiguous; that isn't what I meant. I was suggesing that he take a quick look at objdumps (or for that matter, just find the libs and compare C code) to see what the difference in software emulation of floating point arithmetic is between the two processors. From the descriptions above it sounds awfully like a software library difference. Now, as far as improving things on the Nios II side, there are those FP units available for download and test that have helped a number of people out in their designs -- the trade-off is whether you can afford to spend the additional FPGA LEs... I guess I was just trying to highlight the availability of those as potential solutions. Hope this makes what I was trying to convey less ambiguous.
