'Nios2' 'Nios II' isa compatible to newer buildroot toolchain
Hello @all,
is NiosII cpu isa (instruction set architecture, summary?) compatible within all NiosII implementations over years NiosII has been available (>2004?), yet?
Is buildroot toolchain's compiler (nios2-linux-gcc or nios2-buildroot-linux-gcc) suitable for compiling kernel and how to download a u-boot (or other bootloader) to a preset (.sof, .sopc) fpga environment through Usb blaster programmer/jtag-debugger.
Thanks @all for Your time and efforts.
Sincerely, beyondTime
( nios2eds 13.0sp1, Xenial 16.04 )
background information beside technical context https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pr/nios2_backgrounder.pdf
- EricMunYew_C_Intel
Yes, the Nios II ISA are compatible among all variants.
You can refer to below for Nios II builroot toolchain:
https://rocketboards.org/foswiki/Documentation/NiosIILinuxUserManualForCycloneIII
- beyondTime
Thank you for replying.
Maybe it is easier directly loading a Linux Kernel to start entry point instead of adjusting u-boot to preconfigured Nios II setup.
Just learned that this start entry point can vary for every new hardware configuration, if enabled hardware changes memory, interrupt and peripherals maps.
beyondTime
