16 years agonios2 linux update 20100616
The nios2mmu branch is updated to v2.6.34. Thanks to the community nios2 linux development team, especially Tobias.
A new tarball nios2-linux-20100616.tar is made, and will be available for download soon. A board layer is introduced. The location of fpga header and config.c are moved. Please check out the [Board layer] section in the wiki, http://nioswiki.com/linux/creating_a_nios_ii_design_with_an_mmu Cheers, Hippo8 Replies
Great !
Thanks, -Michael - Altera_Forum
Please find the new tarball,
http://www.niosftp.com/pub/linux/nios2-linux-20100621.tar It is also available at a mirror. Try this only if you can not access niosftp,the bandwidth is limited. http://sopc.et.ntust.edu.tw/pub/linux/nios2-linux-20100621.tar ftp://sopc.et.ntust.edu.tw/pub/linux/nios2-linux-20100621.tar - Hippo - Altera_Forum
does this branch work on DE2-70 well?
it seems that this release only supports 3c120 and NEEK board. - Altera_Forum
I am afraid whether this tar will support DE3?or could you give some solution to add DE3 platform in menuconfig.
hi,
can anyone write some instructions about running uclinux on de3? - Altera_Forum
lulin and wangyipin:
Please see this page linked in the original post: http://nioswiki.com/linux Porting Linux to any particular board involves running the sopc command listed on the wiki to create a header file and choosing the drivers for your peripherals in menuconfig. Once you have it working you can save this configuration as a new "vendor" -- this is also documented on the wiki. As far as I know, the distribution is moving away from shipping preconfigured headers, much less kernel/driver configurations for specific boards in the distribution. - Altera_Forum
Hi
I search for this solution as well 45 minutes ago. Before this i have ported uclinux on the stratix II developement board. I took the DE3_150_DDR2_1G_1RANK reference design from the de3 system design cd and try port uclinux on that system. First problem i encounter is that the nios2-terminal hang after this display on the terminal: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 4-1.2]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Then i checked the system design again and found that the cpu reset vector and Exception vector are on onchip_mem Then I disable the onchip_mem and connect the cpu instruction master and data master to the altmemddr which is the high performance DDR2 SDRAM. Then i reconfigure the cpu reset vector and exception vector to altmemddr, regenerate and recompile the design. After all the configuration, the uClinux amazingly boots up. :D hope this helps.
