16 years agonios2-linux-uclibc-ld.real: cannot find -lieee
Hi, I'm tryining to compile dist10 mp3 decoder source for UcLinux but this appears when I run the make file
$ nios2-linux-gcc -o decode common.o decode.o huffman.o ieeefloat.o musicout.o portableio.o -lm -lieee /opt/nios2/usr/bin/nios2-linux-uclibc-ld.real: cannot find -lieee On gcc everthing runs great but I've this problem. Anybody has suggestions that helps me to solve this problem?? Many thanks for any help1 Reply
When I run $ locate libieee this appears:
/usr/lib/libieee.a /usr/lib/libieee1284.so.3 /usr/lib/libieee1284.so.3.2.2 /usr/lib/xen/libieee.a /usr/share/doc/libieee1284-3 /usr/share/doc/libieee1284-3/README /usr/share/doc/libieee1284-3/TODO /usr/share/doc/libieee1284-3/changelog.Debian.gz /usr/share/doc/libieee1284-3/changelog.gz /usr/share/doc/libieee1284-3/copyright /var/lib/dpkg/info/libieee1284-3.list /var/lib/dpkg/info/libieee1284-3.md5sums /var/lib/dpkg/info/libieee1284-3.postinst /var/lib/dpkg/info/libieee1284-3.postrm /var/lib/dpkg/info/libieee1284-3.shlibs libieee.a doens't appears on gcc-toolchain.. what I should do to include it? Updated: I just modified these MakeFile lines an works correctly CC = gcc CC = nios2-linux-gcc LIBS = -lm lbieee LIBS = -lm
