16 years agonios2-linux-gnu-gcc: not found ?
Hi, I've downloaded everything correctly. I'm using the binary toolchain, after run $make menu config, and the execute
$make vendor_hwselect SYSPTF=/windows/altera/DE2_SD_Card_Audio/system_0.ptf This appears: make ARCH=nios2 -C vendors vendor_hwselect make[1]: nios2-linux-gnu-gcc: Comando não encontrado make[1]: Entrando no diretório `/windows/nios2-linux/nios2-linux/uClinux-dist/vendors' make -C /windows/nios2-linux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/windows/nios2-linux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /windows/nios2-linux/nios2-linux/uClinux-dist/vendors/vendors-common.mak vendor_hwselect /bin/sh: nios2-linux-gnu-gcc: not found make[2]: Entrando no diretório `/windows/nios2-linux/nios2-linux/uClinux-dist/vendors/Altera/nios2' make hwselect /bin/sh: nios2-linux-gnu-gcc: not found /bin/sh: nios2-linux-gnu-gcc: not found make[3]: Entrando no diretório `/windows/nios2-linux/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[3]: *** Sem regra para processar o alvo `hwselect'. Pare. make[3]: Saindo do diretório `/windows/nios2-linux/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[2]: ** [vendor_hwselect] Erro 2 make[2]: Saindo do diretório `/windows/nios2-linux/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[1]: ** [vendor_hwselect] Erro 2 make[1]: Saindo do diretório `/windows/nios2-linux/nios2-linux/uClinux-dist/vendors' make: ** [vendor_hwselect] Erro 2 The binary toolchain has nios2-linux-gcc but not nios2-linux-gnu-gcc1 Reply
hi,
you should follow the instruction of candido in this thread: http://www.alteraforum.com/forum/showthread.php?t=23549 I have successfully built my images.
