Thanks for reply,
But i downloaded the old version nios2-linux, as i told am trying to run uclinux on DE0-Nano, for iam trying to generate the linux imagae, but i failed .
make menuconfig
- Under Vendor/Product Selection, choosed Altera as the Vendor, and nios2 as the Altera Products.
- Under Kernel/Library/Defaults Selection, i have to choose Customize Kernel Settings, but its not selected, what i have to to?
at last if run "make" command its showing error as mentioned below
lex@alex:~/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist$ make
ln -sf staging-pkg-config tools/nios2-linux-uclibc-pkg-config
rm -f /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/../linux-2.6 O=/home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x -j4 zImage || exit 1
make[1]: Entering directory `/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6'
/bin/sh: 1: nios2-linux-uclibc-gcc: not found
make[2]: nios2-linux-uclibc-gcc: Command not found
CHK include/asm-nios2/nios2.h
perl -I/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6/arch/nios2/scripts /home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6/arch/nios2/scripts/gen_nios2.
h.pl cpu sdram < /home/alex/uClinux/hardware/DE0-Nano/simple/DE0_Nano_SOPC.ptf > include/asm-nios2/nios2.h.tmp; if [ -r include/asm-nios2/nios2.h ] && cmp -s include/asm-nios2/nios2.h include/asm-nios2/nios2.h.tmp; then rm -f include/asm-nios2/nios2.h.tmp; else echo ' UPD include/asm-nios2/nios2.h'; mv -f include/asm-nios2/nios2.h.tmp include/asm-nios2/nios2.h; fi
GEN /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
CHK include/linux/version.h
CHK include/linux/utsrelease.h
SYMLINK include/asm -> include/asm-nios2
Using /home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6 as source for kernel
CC scripts/mod/empty.o
make[4]: *** [scripts/mod/empty.o] Error 127
make[3]: *** [scripts/mod] Error 2
make[2]: *** [scripts] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6'
make: *** [linux] Error 1
Any help?
