22 years agoNios2 Internal Memory
About a year ago, I started a pinewood derby timer as a home project. At the time, I developed a PC application that would control/receive data from a timer. I had an Altera up-1 board with a 10K70...
22 years agoStill have not been able to get the Nios2 to boot from internal memory. I did however notice after looking at the object dump that my code starts at 0x1100 (RAM base is 0x1000). Using the nios2-console, a reset put the pc at 0x1000. I am assuming that there is some reset code that the NIOS2 sdk provided. When I use the SOPC builder, should I set the reset vector to 0x1100, or leave it alone. Doesn't look like it is not using the reset vector correctly. Please help.....
Rick
