22 years agoNios2 Internal Memory
About a year ago, I started a pinewood derby timer as a home project. At the time, I developed a PC application that would control/receive data from a timer. I had an Altera up-1 board with a 10K70...
22 years agoI understood everything except the run from reset part. If you download the code it works but then you reset the system and it stops because it doesn't come out of reset? If that's the case it might be the timer that times out, or you're RAM being corrupted coming out of reset (.... don't really know since I'm not sure of the question really)
