13 years agoNios2 instruction and data master ports could be variable width when cache is used?
Hi, I was thinking about the Nios2 architecture today and I have to ask why the Nios2 doesn't employ a variable width instruction and data master port when the Nios2 is configured to use cache?...
13 years ago --- Quote Start --- I suspect it would be a lot of logic for a small gain in very few configurations. FPGA pins ar usually at a premium - so a 64bit external data bus would be unusual. There are a lot of other places where a relatively small amount of logic would improve performance in configurations that are more likely to be used. --- Quote End --- Since, presumably, this extra logic would be instantiated only in situations where it was useful, then then the issue occurs only for the person who maintains the Nios2 IP, and we wouldnt have concerns about excessive logic consumption in the FPGA. My naive perspective is that, when there is a cache in the Nios2, the logic for copying from memory to cache wouldnt be complex, and maybe supporting different instruction and data port widths wouldnnt be a burden. Jeff
