16 years agonios2-ide vs nios2-bsp
I don't like to use Eclipse and the NIOS2-IDE. I'm usually much more effective with the tools I'm familiar with like: emacs, make, gcc, gdb, linker scripts, objdump, etc. However I can't seem t...
16 years ago --- Quote Start --- I didn't know that sopc_builder did take any arguments. --- Quote End --- I always thought that sopc_builder was a GUI only application. Well, it's sort of as it's not totally happy running without DISPLAY unset under Linux as I get:
Info: Generating the Example Design.
Info: Generating the Pin Planner file.
Info: Generating the Synopsys Design Constraints file for the example top level.
java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159)
at java.awt.Window.<init>(Window.java:406)
at java.awt.Frame.<init>(Frame.java:402)
at java.awt.Frame.<init>(Frame.java:367)
I do builds at night started from cron so this is a little cumbersome as I have to make a dummy X display and set the DISPLAY variable to it.
