16 years agonios2-ide vs nios2-bsp
I don't like to use Eclipse and the NIOS2-IDE. I'm usually much more effective with the tools I'm familiar with like: emacs, make, gcc, gdb, linker scripts, objdump, etc. However I can't seem t...
16 years ago --- Quote Start --- You can specify all of these options from the --set --- Quote End --- Thanks! The --set commands seem to be quite useful. However, I need to explore it further in order to generate the same as NIOS2-IDE.
