20 years agoNIOS2 IDE Team CVS
Hello, I tried to set up cvsnt server to cooperate with NIOS2 IDE. When trying to start sharing a project with CVS, I get the Error "CVSNT repository "..." os configured to use a repository p...
20 years agoHi have to correct my self:
<div class='quotetop'>QUOTE </div> --- Quote Start --- when trying to upgrade manually higher, IDE got smashed fully... new install needed[/b] --- Quote End --- Last time, i tried to update the old ide via update sites... that has failed. I tried again with a original Eclipse 3.1.2: - renamed folder ...\nios_51\bin\eclipse to ...\nios_51\bin\eclipse_altera for backup - copied full eclipse 3.1.2 to ...\nios_51\bin\eclipse - copied all altera related plugins and features to the new eclipse directory (everthing with altera in its name...) - copied nios2-ide.exe into ...\nios_51\bin\eclipse - launched nios2-ide.exe and got a running enviroment: But there are some disadvantages because of incompability between altera plugins and eclipse 3.1.x: - Several errors on start up about missing function in cygwin1.dll - Creating Template Application does not work - Edit Run-Configuration does not Work - Flash Programmer does not work But happliy "compile", "run", system property page works and ... team CVS on cvsnt http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif The popping errors at beginning can be avoided by not using nios2-ide.exe: create a file: start.bat into ...\nios_51\bin\eclipseC:\altera\quartus51\bin\jre\bin\javaw.exe -Xmx256m -cp C:\altera\kits\nios2_51\bin\eclipse\startup.jar org.eclipse.core.launcher.Main -os win32 -ws win32 -arch x86 -vm C:\altera\quartus51\bin\jre\bin\javaw.exe -vmargs -Xmx256m -cp C:\altera\kits\nios2_51\bin\eclipse\startup.jar org.eclipse.core.launcher.Main and launch it over the nios2-shell, not from windows command line !!!!!! this is very important because all gnu tool will run in the same shell as the javaw.exe and it must be the cygwin shell. well... i like the newer eclipse because there are lots of features in the cdk for all the things i cannot do , i do using the saved eclipse ide by simply launching backup copy ..\nios_51\bin\eclipse-altera\nios2-ide.exe it seems to work fine, also if its directory name has changed... well... hopefully, altera will update its ide some time themself... then things will be easier http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif addon: little late now, i figure out that there exist a workaround for older eclipse version to work with cvsnt server: https://bugs.eclipse.org/bugs/show_bug.cgi?id=39516 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=39516) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif regards, marek
