16 years agoNios2 IDE produces different binaries in Windows vs. Linux
We develop Nios code in a mixed-os environment using Nios 2 IDE version 9.0 sp2. Recently, I needed to debug some running code using attach mode on a windows laptop and could not get the debugger to...
16 years agoI never looked at the intermediate objects directly, so I don't know about the differences at that stage.
As for the completed elfs, it's kinda difficult to quantify how different they are but the windows debugger couldn't make heads or tails of any of the addresses it was getting from the running binary. I diffed the objdumps and noticed significant differences in the asm generated. The 9.0 nios build scripts don't show the full command when building each file. I used the same project files on both Windows and Linux though, so wouldn't it stand to reason that the nios build scripts would use the same settings? If there is any other info I can provide, let me know! Thanks :-)
