16 years agoNios2 IDE produces different binaries in Windows vs. Linux
We develop Nios code in a mixed-os environment using Nios 2 IDE version 9.0 sp2. Recently, I needed to debug some running code using attach mode on a windows laptop and could not get the debugger to...
16 years agoHow different are the object files?
I don't believe the gcc code has changed recently, so maybe you are passing different options to the compiler. However you may need to sort out how to copy the program you built on linux over to the laptop for debugging. (This relies on you being able to run the debugger without reruning the compiler.)
