21 years agoNIOS2 ide flash programmer bug ?
Hello, Does anyone have experimented this ? I have created a target board for my custom board with mk_taget_board. I have a Quartus project and a software that work fine. I can use the comm...
21 years agoWhere (in which directory) is your target board component located? Did you place it in the <nios2_rootdir>/components directory? Alternately, you could place it in a different directory and then change your SOPC_BUILDER_PATH to point to it.
From the behaviour you're describing, it sounds like your target board component is not in one of the standard component search locations. Cheers, - slacker
