nios2-gdb-server.exe: command not found
After a long time I have a project for fpga and nios 2. I downloaded quartus 20.1.1. After many, many problems, I installed it and put it in working order. According to the posts on the discussion forum. The IDE quartus starts, I create a project with nios 2, the eclipse goes and starts, I create a project and compile the program.
But I can't get over this error:
nios2eds/bin/nios2-download: line 544: nios2-gdb-server.exe: command not found
Older versions worked. As of version 19, it is a non-functional development environment.
- BoonBengT_Altera
Moderator
Hi @jca,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
Can you please share what are the nios ii command line used which caused that error? Did you managed to try with a more simple project (i.e. hello world template) to see if it works? And I believe you have WSL installed on your environment yes?Hope to hear from you soon.
Thank you.Best Wishes
BB- BoonBengT_Altera
Moderator
Hi @jca,
Hope this message find you well and good day, unfortunately as we do not receive any response from you to the previous clarification that we have provided. Would recommend to try and installed Cygwin and run eclipse-nios2.exe to see if eclipse able to start gdbserver correctly.
This thread will now be transitioned to community support. If you have new queries, please feel free to open a new thread to get support from Intel experts. Otherwise, the community users will further help you with doubts in this thread.
Best Wishes
BB- FernandoI
I am also having this problem. How hard is it to make things work with these intel Nios II / FPGA even following a simple tutorial?
My error is:
"/mnt/c/intelfpga_lite/20.1/nios2eds/bin/nios2-download: line 544: nios2-gdb-server.exe: command not found "I have found this to be true, since there is no "nios2-download" folder nor any "nios2-gdb-server.exe". I was wondering if there is any instructions of what to do in this case. Should I download it myself? is there an alternative?
