12 years agonios2-gdb-server Assertion `!flush || m_pending.empty()' failed
Hi, I am working on some nios2 software to be embedded in a hardware design outside of my control. After I load the software, I am intermittently seeing the following error from nios2-gdb-serve...
11 years agoHi,
I also have had a similar problem: assertion "!flush || m_pending.empty()" failed: file "nios2oci.cpp", line 1234/cygdrive/c/altera/13.1/nios2eds/bin/nios2-download: line 609: 3372 aborted (core dumped) nios2-gdb-server --cable '' --device 1 --instance 0 --sidp 0x74003e00 --accept-bad-sysid --tcpport auto --write-pid ./nios2-download.pid In my case not sure if it is a timing issue, most of the times it is solved by running the synthesis again without cleaning the project... Has any one had a similar problem and was able to find what was the cause? Best regards, Filipe Teixeira http://about.me/teixeirafms
