17 years agonios2-gcc compiler
Hi, I am new to uc linux. I have downloaded the nios2-gcc tool chain from ftp://ftp.altera.com/outgoing/nios2gcc-20080203.tar.bz2 (ftp://ftp.altera.com/outgoing/nios2gcc-20080203.tar.bz2) on ...
17 years ago<div class='quotetop'>QUOTE (Muralidhar @ Jul 21 2009, 01:20 PM) <{post_snapback}> (index.php?act=findpost&pid=23223)</div>
--- Quote Start --- http://www.nioswiki.com/operatingsystems/uclinux (http://www.nioswiki.com/operatingsystems/uclinux) "If you have only a Windows PC, you can still construct a Linux environment using coLinux , which will run under Windows, see Nios2Colinux . You may use VMWare, too. But they may be difficult for a Linux newbie. Note, you cannot use Linux shell to program JTAG on coLinux under Windows. You must use Nios II command shell for Windows to program JTAG in this case".[/b] --- Quote End --- I should not answer as you again greatly abused the quoting, misusing the Forum software. Anyway: What is it that you don't understand in the forum quote? Developing on Windows is not possible. If you need to run Windows for some other purpose and you have only one PC, you can install VMWare to run Linux additionally. Dis does work, if you have at least 2 GByte RAM, but it's slower than a natively installed Linux. Building the tool chain and building the software for the NIOS completely is in the Linux environment, Windows is not seen at this point. -Michael
