20 years ago
nios2-flash-programmer
I'd like download a .sof in memory, so I used this code:
$ sof2flash --input=de2_net.sof --output=de2_net.flash --offset=0x0
$ nios2-flash-programmer --base=0x0 DE2_net.flash
but I think that the --base adress is not good.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
No CFI table found at adress 0x00000000
Leaving target processor paused[/b]
--- Quote End ---
Should I better create a "srec" file ?
What is the --base adress for the SREC or the FLASH file (in DE2 board) ?
Thanks!
1 Reply
    --- Quote Start ---
    originally posted by pairin20@May 15 2006, 07:03 AM
    hi,
    i&#39;d like download a .sof in memory, so i used this code:
    $ nios2-flash-programmer --base=0x0 de2_net.flash
    but i think that the --base adress is not good.
    <div class='quotetop'>quote </div>
    --- quote start ---
    no cfi table found at adress 0x00000000
    leaving target processor paused
    --- Quote End ---
    Thanks!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15363)</div>
    [/b]
    --- Quote End ---
    DE2 uses EPCS16 for configuration, not CFI.
    You have to program sof to EPCS.
