21 years agonios2-flash-programmer ERROR
Hi, I have custom board with following specification: Flash memory: S29GL064M90TAIRO FPGA: Startix with NiosII EPM7128 - configuration controller Board design similar to Stratix...
21 years ago --- Quote Start --- originally posted by fischer@Jan 21 2005, 11:15 AM can you make the following test:
- download your fpga.sof with quartus programmer to fpga.
- run the memory test program from altera,(ide -> new projects -> project template -> memory test)
from ram with the debugger. --- Quote End --- Hi, All memory (FLASH, SDRAM, SRAM) tests OK. Has someone flash downloader code for free? Thanks.
