20 years agonios2-flash-programmer and Version 4.2
Hello I have troubles flashing a file with nios2-flash-programmer. The installed versions are: - Quartus Version 4.2 with service pack 1 installed - Altera SOPC Builder 4.2 Build 178 ...
20 years agoThe 2 lines I had to create because of not leave floating 2 lines of the flash. But if it would have worked I would have been very surprised. Normally the Avalon bus handels this.
I work with Version 4.2 because of using the plugs library of Altera (SDK support). As soon as there is a TCP/IP stack running without RTOS I will make a change to the new versions and work with Nios II IDE. I did not make any changes to the AMD29LV065D-120R. If the nios2-flash-programmer does not work with the version 4.2 I have to use the old tools to flash a program.
