20 years agonios2-flash-programmer and Version 4.2
Hello I have troubles flashing a file with nios2-flash-programmer. The installed versions are: - Quartus Version 4.2 with service pack 1 installed - Altera SOPC Builder 4.2 Build 178 ...
20 years agoversion 4.2 have lots of problem with the flash programmer.
it's better to move to 5.1 i'm sorry if i was miss understood but i didn't ment that you should create 2 more lines. i ment that you should ignore 2 lines. but any way AMD29LV065D-120R is an 8MB with 8 bit data and so there shouldn't be a problem of miss alignmnet. have you made any changes to its settings??? what is your data width????? if you would have used AMD29LV128M-123R you would have seen this problem. if you have made any changes to the AMD29LV065D-120R then i'm sorry , no more idea
