20 years agonios2-flash-programmer and Version 4.2
Hello I have troubles flashing a file with nios2-flash-programmer. The installed versions are: - Quartus Version 4.2 with service pack 1 installed - Altera SOPC Builder 4.2 Build 178 ...
20 years agoThank you for your answers.
Like you assumed I made my target board with mk_target_board utility. After that I added a default Flash (AMD29LV065D-120R like on the cyclon eval. boards) and after assigned the pins in Quartus SOPC builder. I made all the steps like described in the ug_nios2_flash_programmer.pdf. Now I did test your suggestion. Based on the default Flash (AMD29LV065D-120R) I had to define 2 more address lines to get a[24..0] (so the flash have 64MB instead 8MB). After I connected the address lines a[24..2] to the flash. But the messages were the same. Do you know if the versions 4.2 works? Do you have any other idea?
