19 years agonios2-elf MingW
Anyone tried to compile the toolchain with MingW?
Is it going well with not too much effort/patches/...? Stefaan1 Reply
I made some progress on it, just have a problem now with building libstdc++
seems that it can not find the file cstddef, but the file is available
Any idea?make: Entering directory `/c/nios2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/libsupc++' /bin/sh ../libtool --tag CXX --tag disable-shared --mode=compile /c/nios2-src-6.1/gcc/build/gcc/xgcc -shared-libgcc -B/c/nios2 -src-6.1/gcc/build/gcc/ -nostdinc++ -L/c/nios2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/src -L/c/nios2-sr c-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/src/.libs -Bc:/nios2-6.1/nios2-elf/bin/ -Bc:/nios2-6.1/nios2-elf/l ib/ -isystem c:/nios2-6.1/nios2-elf/include -isystem c:/nios2-6.1/nios2-elf/sys-include -mcustom-fpu-cfg=60-1 -I/c/nios2-src- 6.1/gcc/libstdc++-v3/../gcc -I/c/nios2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/include/nios2-elf -I/c/ni os2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/include -I/c/nios2-src-6.1/gcc/libstdc++-v3/libsupc++ -O2 -g -O2 -g -O2 -mcustom-fpu-cfg=60-1 -fno-implicit-templates -Wall -W -Wwrite-strings -Wcast-qual -fdiagnostics-show-location= once -c -o del_op.lo ../../../../../libstdc++-v3/libsupc++/del_op.cc /c/nios2-src-6.1/gcc/build/gcc/xgcc -shared-libgcc -B/c/nios2-src-6.1/gcc/build/gcc/ -nostdinc++ -L/c/nios2-src-6.1/gcc/build/ nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/src -L/c/nios2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/src/. libs -Bc:/nios2-6.1/nios2-elf/bin/ -Bc:/nios2-6.1/nios2-elf/lib/ -isystem c:/nios2-6.1/nios2-elf/include -isystem c:/nios2-6.1 /nios2-elf/sys-include -mcustom-fpu-cfg=60-1 -I/c/nios2-src-6.1/gcc/libstdc++-v3/../gcc -I/c/nios2-src-6.1/gcc/build/nios2-elf /mcustom-fpu-cfg=60-1/libstdc++-v3/include/nios2-elf -I/c/nios2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/ include -I/c/nios2-src-6.1/gcc/libstdc++-v3/libsupc++ -O2 -g -O2 -g -O2 -mcustom-fpu-cfg=60-1 -fno-implicit-templates -Wall -W -Wwrite-strings -Wcast-qual -fdiagnostics-show-location=once -c ../../../../../libstdc++-v3/libsupc++/del_op.cc -o del_op.o In file included from ../../../../../libstdc++-v3/libsupc++/del_op.cc:31: ../../../../../libstdc++-v3/libsupc++/new:41:19: cstddef: No such file or directory In file included from ../../../../../libstdc++-v3/libsupc++/del_op.cc:31: ../../../../../libstdc++-v3/libsupc++/new:82: error: declaration of `operator new' as non-function ../../../../../libstdc++-v3/libsupc++/new:82: error: `size_t' is not a member of `std' ../../../../../libstdc++-v3/libsupc++/new:82: error: expected `,' or `;' before "throw" ../../../../../libstdc++-v3/libsupc++/new:83: error: declaration of `operator new ' as non-function ../../../../../libstdc++-v3/libsupc++/new:83: error: `size_t' is not a member of `std' ../../../../../libstdc++-v3/libsupc++/new:83: error: expected `,' or `;' before "throw" ../../../../../libstdc++-v3/libsupc++/new:86: error: declaration of `operator new' as non-function ../../../../../libstdc++-v3/libsupc++/new:86: error: `size_t' is not a member of `std' ../../../../../libstdc++-v3/libsupc++/new:86: error: expected primary-expression before "const" ../../../../../libstdc++-v3/libsupc++/new:86: error: expected `,' or `;' before "throw" ../../../../../libstdc++-v3/libsupc++/new:87: error: declaration of `operator new ' as non-function ../../../../../libstdc++-v3/libsupc++/new:87: error: `size_t' is not a member of `std' ../../../../../libstdc++-v3/libsupc++/new:87: error: expected primary-expression before "const" ../../../../../libstdc++-v3/libsupc++/new:87: error: expected `,' or `;' before "throw" ../../../../../libstdc++-v3/libsupc++/new:92: error: declaration of `operator new' as non-function ../../../../../libstdc++-v3/libsupc++/new:92: error: `size_t' is not a member of `std' ../../../../../libstdc++-v3/libsupc++/new:92: error: expected primary-expression before "void" ../../../../../libstdc++-v3/libsupc++/new:92: error: expected `,' or `;' before "throw" ../../../../../libstdc++-v3/libsupc++/new:93: error: declaration of `operator new ' as non-function ../../../../../libstdc++-v3/libsupc++/new:93: error: `size_t' is not a member of `std' ../../../../../libstdc++-v3/libsupc++/new:93: error: expected primary-expression before "void" ../../../../../libstdc++-v3/libsupc++/new:93: error: expected `,' or `;' before "throw" make: *** Error 1stefaan@PC160 /c/nios2-src-6.1/gcc/build/nios2-elf/mcustom-fpu-cfg=60-1/libstdc++-v3/include $ ls Makefile clocale cwchar istream set stamp-std algorithm cmath cwctype iterator sstream stdexcept backward complex debug limits stack streambuf bits csetjmp deque list stamp-backward string bitset csignal ext locale stamp-bits utility cassert cstdarg fstream map stamp-c_base valarray cctype cstddef functional memory stamp-c_compatibility vector cerrno cstdio iomanip nios2-elf stamp-debug cfloat cstdlib ios numeric stamp-ext ciso646 cstring iosfwd ostream stamp-host climits ctime iostream queue stamp-nios2-elf
