22 years agonios2-elf-gcc: not found
I' am trying to build a uClinux but I get errors. This is my output: Microtronix Linux Extensions Version 1.2, Built Wed Jul 27 3:46pm EST 2004 ------------------------------------------------ make: Entering directory `/cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' nios2-elf-gcc: not found nios2-elf-gcc: not found Using /cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel nios2-elf-gcc: not found SYMLINK include/asm -> include/asm-nios2nommu nios2-elf-gcc: not found nios2-elf-gcc: not found HOSTCC scripts/basic/fixdep scripts/basic/.fixdep.d: done. HOSTCC scripts/basic/split-include scripts/basic/.split-include.d: done. HOSTCC scripts/basic/docproc scripts/basic/.docproc.d: done. nios2-elf-gcc: not found HOSTCC scripts/conmakehash scripts/.conmakehash.d: done. HOSTCC scripts/kallsyms scripts/.kallsyms.d: done. HOSTCC scripts/mk_elfconfig scripts/.mk_elfconfig.d: done. MKELF scripts/elfconfig.h HOSTCC scripts/file2alias.o scripts/.file2alias.o.d: done. HOSTCC scripts/modpost.o scripts/.modpost.o.d: done. HOSTCC scripts/sumversion.o scripts/.sumversion.o.d: done. HOSTLD scripts/modpost HOSTCC scripts/pnmtologo scripts/.pnmtologo.d: done. HOSTCC scripts/bin2c scripts/.bin2c.d: done. nios2-elf-gcc: not found nios2-elf-gcc: not found make[2]: *** [arch/nios2nommu/kernel/asm-offsets.s] Error 127 make[1]: *** [arch/nios2nommu/kernel/asm-offsets.s] Error 2 make: *** [all] Error 2 CC arch/nios2nommu/kernel/asm-offsets.s make: Leaving directory `/cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' Does anybody know what's wrong? Thanks, Hans1 Reply
please see the topic above yours. It has a workaround. I assume your problem is the same.
