19 years agonios2-elf-gcc: command not found
Hello All ! I use Toolchain to build kernel but after - I install Toolchain - make menuconfig - make vendor_hwselect SYSPTF=~/hardware/1c12.ptf - make romfs - make ...
19 years agoHello All !
this is error message when make romfs : ....... romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_S HADOWPASSWDS -s config/shadow /etc/shadow for i in uClibc /home/vietluong/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done /bin/sh: nios2-elf-gcc: command not found /bin/sh: nios2-elf-gcc: command not found /bin/sh: nios2-elf-gcc: command not found make[2]: Entering directory `/home/vietluong/uClinux-dist/uClibc' [ -e /home/vietluong/uClinux-dist/romfs/lib ] || mkdir /home/vietluong/ uClinux-dist/romfs/lib /bin/sh: nios2-elf-gcc: command not found if [ "" ]; then romfs-inst.sh /lib/lib.so; fi make[2]: Leaving directory `/home/vietluong/uClinux-dist/uClibc' make[1]: Leaving directory `/home/vietluong/uClinux-dist/lib' make[1]: Entering directory `/home/vietluong/uClinux-dist/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/home/vietluong/uClinux-dist/include' make[1]: Entering directory `/home/vietluong/uClinux-dist/user' for i in boa busybox cgi_generic dhcpcd-new ftp games inetd init sash t elnetd /home/vietluong/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entering directory `/home/vietluong/uClinux-dist/user/boa' for i in src ; do make -C $i romfs || exit ; done make[3]: Entering directory `/home/vietluong/uClinux-dist/user/boa/src' romfs-inst.sh /bin/boa cp: cannot stat `boa': No such file or directory make[3]: *** [romfs] Error 1 make[3]: Leaving directory `/home/vietluong/uClinux-dist/user/boa/src' make[2]: *** [romfs] Error 2 make[2]: Leaving directory `/home/vietluong/uClinux-dist/user/boa' make[1]: *** [romfs] Error 2 make[1]: Leaving directory `/home/vietluong/uClinux-dist/user' make: *** [romfs.subdirs] Error 1 PLEAPLE HELP ME !
