19 years agoNios2 EDS 6.1 installation problem in SuSE 10
Says unable to confirm Quartus II 6.1 installation, which was in /opt and works fine. New to SuSE and Linux, please help with some detailed installation % configuration procedures. Thanks
19 years agoNios2EDS was installed successfully. (after reboot)
According to prompt instruction: added QUARTUS_ROOTDIR=${QUARTUS_ROOTDIR:-/....} export QUARTUS_ROOTDIR to env.sh then did ./nios2-ide in /nios2_6.1/bin/eclipse failed as: An environment variable required by the Nios II IDE is not set. The environment variable is QUARTUS_ROOTDIR. How where to set that, like slacker mentioned. Thanks
