13 years agonios2-download Verify Failed
Thanks in advance. We are finally getting a chance to migrate to the mmu branch. Our goal is to use the TSE and Marvell. We've seen in the wiki that we will need to do some adds to the *.dts...
13 years agoThat's not right -- that's the value you should put in "Memory base address". The "Link address offset for booting" is an *offset* in your RAM, so it needs to be smaller than the size of your RAM. It's where the image gets loaded before bing uncompressed into the beginning of RAM, so memory size minus approximate size of image minus some leg room gets you a reasonable offset. 2/3 the size of your RAM is also a good rule of thumb.
The download should then start at kernel virtual offset + "Memory base address" + "Link address offset for booting". So in your case, something like 0xD2000000.
