12 years agonios2-download on command line not working
I am attempting to use the demo project for the DE3 DDR2 example. Whenever the batch file (contents listed way below) gets to the line nios2-download, it gives errors about the command. I tri...
12 years agoIts been so long ago that I had this but I think it was a problem of the unix to dos problem. So, I remember taking all the script files (plain text) and running the dos2unix on the file. Do, nios2-download is a script call to other files some executables. So, do this on that file
dos2unix nios2-download And it changes the line endings to the right format for cygwin. I think if you ran the command in windows command window, it would be needed but cygwin is Unix-like. --- Quote Start --- I´m experiencing exactly the same problem. Were you able to find the solution to that? I´m using Win7-64 and have cygwin installed. Cheers, Bruno --- Quote End ---
