11 years agonios2-download hangs, then "There is a problem with your Quartus II installation"
Two months using DE1-kit with Quartus 7.2 from CDROM on Windows Vista 32 bit Home Basic. Worked fine for 2 months, then, just as learning how to use RAM memory in SOPC, nios2 "blew-up." I can downl...
11 years ago --- Quote Start --- Have you installed the 13.1 service pack 3? --- Quote End --- Thanks for picking this up. No, but I ** do ** have version 13 (.1 or .01) on the Linux side which is working. I think I will just give up on trying to resurrect the version 7.2 I had installed on the Windows Vista side. I believe the USBBlaster driver just doesn't install correctly by itself, barring a complete re-install, which had its own problems. I will just give up on version 7.2 now, because it's just too hard! As for installing the old windows 7.2 driver, some of the registry entries installed using the .inf file, but others would not install. So, after many failed attempts with Windows, I will use Linux.
