16 years agonios2-download error with MMU
Hi, I work on the nios2 kit 2C35. I would like to switch on linux with MMU after a µClinux Evalution. I have met a problem during the flash programming. ("nios2-download -g linux.initram...
16 years ago --- Quote Start --- [...] its loading address, which must be offset-ed with 0xc0000000 if I'm not wrong... --- Quote End --- Do you know what means this offset ? I've found the problem, it was a bad timing on the SDRam. All seems OK now.
