Oliver_I_Sedlacek
Contributor
2 years agoNIOS2 doesn't automatically run from external RAM, how to debug
I really need my NIOS2 to autostart and run from off chip RAM using the bootloader copy method. The trouble is that despite many readings of the handbook and multiple rebuilds of the design the code ...
tehjingy_Altera
2 years agoHi Oliver
I am stuck at the same stage as you.
In the example design I am creating the bootcopier is not copying the values to the memory.
Tested my NiosII application accessing the flash is working.
Currently will be checking on the reset vector being passed to the bootcopier.
Will be updating you on my testing.
Jingyang, Teh
