Oliver_I_Sedlacek
Contributor
2 years agoNIOS2 doesn't automatically run from external RAM, how to debug
I really need my NIOS2 to autostart and run from off chip RAM using the bootloader copy method. The trouble is that despite many readings of the handbook and multiple rebuilds of the design the code ...
tehjingy_Altera
2 years agoHi
Any update on this case?
Have you considered running the nios application in place in the flash instead of being copied over to RAM using bootloader?
- Oliver_I_Sedlacek2 years ago
Contributor
I'm pretty stuck, as I'm in the critical stage of a big project and I dare not touch anything in case I have another setback like last time. If I could get hold of anothe Trenz CYC1000 I could try it on that but until Intel improve chip supply I don't have that as an option.
