Oliver_I_Sedlacek
Contributor
2 years agoNIOS2 doesn't automatically run from external RAM, how to debug
I really need my NIOS2 to autostart and run from off chip RAM using the bootloader copy method. The trouble is that despite many readings of the handbook and multiple rebuilds of the design the code ...
tehjingy_Altera
2 years agoHi Oliver
The GSFI is an IP by Intel.
In your case we could use that to test the read and write access to the Flash Storage to be working or not.
Jingyang, Teh
Oliver_I_Sedlacek
Contributor
2 years agoWell the programmer demonstrably writes to flash and the NIOS2 doesn't ever write to flash, so the only use might be to read from flash. This gets me back to my original question, what is in the flash that is wrong?
The only progress we have made in nearly 2 months is to discover that the boot loader isn't copying the application code to external RAM.
I have been promised that an extra engineer would look at this. Can you ask whether that is happening?
