Oliver_I_Sedlacek
Contributor
2 years agoNIOS2 doesn't automatically run from external RAM, how to debug
I really need my NIOS2 to autostart and run from off chip RAM using the bootloader copy method. The trouble is that despite many readings of the handbook and multiple rebuilds of the design the code ...
Oliver_I_Sedlacek
Contributor
2 years agoBy taking the code image out of the FLASH so it just does the configuration I'm running again. I'm back to my original problem, with the additional handicap that I can't afford to break the system as the project is dependent on it.
