19 years agonios2 cyclone 2 problem
Hi there I am very new to the forum and hope anyone there could help. I have designed a SOPC component that seem to work well so far since I can read and write registers from C++(nios2) howe...
19 years agoDid you simulate processor accesses to the peripheral? You might what to check how the register behaves when it is being updated by your hardware when there is a concurrent Avalon access.
--- Quote Start --- originally posted by tantapion+nov 7 2006, 10:20 am--><div class='quotetop'>quote (tantapion @ nov 7 2006, 10:20 am)</div>--- quote start ---
<!--quotebegin-iztok.jeras@Nov 7 2006, 08:47 AM you should always run a simulation of your hdl code before expecting it to work connected to a processor. simulate both the the external stimuli and avalon bus access.
izi
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19262)
--- quote end ---
--- Quote End --- I simulated the HDL code on Sim and everithing works fine <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19264)</div> [/b] --- Quote End ---
