NIOS2 & mSGDMA (Ethernet example)
thank you for your help,
I succeeded in using the mSGDMA devices, in a loopback demo. My understanding is the new TSE driver suite that comes in a BSP requires mSGDMA devices, no longer SGDMA. So now I got something that should be fairly close to what I want. I have a NIOS2 + TSE + two mSGDMA devices and a dedicated OCM for DMA descriptors. The point is I am trying to create a basic design to use the TCP demo application, now I can get the app to start but it is stuck at "Auto negotiation passed" and simply hangs there. The two NicheStack tasks (tick & netmain) are both created. The MDIO interface seems to be working and the drivers seems to do the job. But then it requests a hardware reset, reinitiates a negotiation & just freezes. Any ideas what I might be doing wrong? I noticed on an online tutorial that what comes next is related to DMA devices, could that possibly be related to my OCM/DMA whatever SOC I did wrong? https://alteraforum.com/forum/attachment.php?attachmentid=15825&stc=1Hi,
I am trying to implement triple speed ethernet in nios processor using modular scatter gather dma (msgdma) controller. I have build the qsys. For memory i have used ram. I have called 2 msgdma one for receiving in streaming to memory mode and one for transmitting in memory to streaming mode. I have done the interconnections in qsys platform and generated the HDL successfully. The sopcinfo file is also generated. Using this sopcinfo file i tried to generate the bsp. The bsp generates but when i try to build the bsp project in eclipse the build fails. It says that " fatal error. altera_msgdma.h. No such file exists."
I am using Quartus 18.1. I cannot downgrade to lower version as i have progressed a lot in 18.1 and now cannot migrate to a lower version because of dependency issues.
Actually this file is missing in alt_avalon_tse.h. The altera_msgdma.h exists in the installation folder of quartus 18.1 in c drive. But some how when i try to build the bsp it doesn't pick that file and throws the above mentioned error. I have tried to manually move altera_msgdma.h and altera_msgdma.c file into the incude and source file of the driver folder of the project file. After doing this the bsp builds, but the actual project build fails.
Kindly guide
Av
- AKb6 years ago
Kindly guide
Av
