JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
tehjingy_Altera
2 years agoHi Johnson
Could you try with the latest 23.4 Quartus?
I have migrated the latest NiosV example design to the cyclone10 gx board.
I managed to solved the error code 20014.
Now i am stuck with the same error code that you are facing. 2010
Right now i am asking around what could be the cause for this.
Jingyang, Teh
