JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
tehjingy_Altera
2 years agoHi
Sorry for being so slow.
I got a hard time getting your project to work .
I think in your project you did not assigned the pins correctly.
Still trying to migrate and testing out the example design.
attached is so far i managed to get the application running boot into initialization.
Still solving the error code 20014 that i am looking at.
Jingyang, Teh
