JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
tehjingy_Altera
2 years agoHi
I tried it on an Arria10 board. I think it should be okay if we migrate it over to the Cyclone10.
Attached is my project for the Arria10.
Let me try to migrate it to the Cyclone10 board and share u the project again.
Jingyang, Teh
