JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
JLee25
Contributor
2 years agoHi Jingyang,
Thank you for the update.
So you can run the example design on the Cyclone 10 GX device and can telnet it?
If this is the case, would you share me the example?
As I never have any change to connect to the board.
BRs,
Johnson
