JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
tehjingy_Altera
2 years agoHi
Sorry there is a current surge in case and I will need more time in this case.I managed to run the example design and able to connect to the board through Telnet. Currently I will need more time to acquire the signalTap waveform.
Previously when you switch the Example Design to DHCP. Are you able to connect to the board through Telnet?
Jingyang, Teh
