JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
JLee25
Contributor
2 years agoHi,
I modify the design with Nios V to EMIF through a memory mapped clock crossing bridge and DMA through another bridge.
But for unknown reason the DMA bridge is not running...
I STP the bus and found only Nios V is running..
Any suggestions ? DMA driver or ...
- EBERLAZARE_I_Intel2 years ago
Is the DMA & EMIF visible in the "drivers" tab in BSP-editor?
