JLee25
Contributor
2 years agoNios V uC/TCP IP Failed
Hi support, I am learning the simple socket server design on Cyclone 10 GX. For unknown reason, the initialization process stopped with the error code (2010), It's the TSE with DP83848. T...
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
EBERLAZARE_I_Intel
2 years agoHi,
From my findings, the signal issue you mentioned, it seems that it has something to do with some settings that need to be tweaked.
I will further investigate towards that and get back to you soon with some suggested workaround.
Thanks for your patience.
