Nios V uC/TCP IP Failed
- 2 years ago
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
Jingyang, Teh
It's a custom board with C10 GX and DP83848.
We use Nios II with NicheStack in the past and are porting the Niso V now.
So the Hareware should be fine.
The qsys connection is like below.
The Nos V is running on EMIF.
Following your instruction, the socket is running now.
But I can not connect to the server and ping to the specific is not responding..
Form the STP, the ff_rx_a_full is always high.
I think there are problems on the FPGA side since the TSE IP is not responding..
BRs,
Johnson
